Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
 Slow stick elevator warped.... help! >
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 02-07-2005 | 01:01 AM
FlybyPDX's Avatar
Default Slow stick elevator warped.... help!
I am building my third slow stick. When I taped the elevator together it is bowed slightly. So when I move the elevator it jumps back and fourth and is not smooth. How can I fix this. I have tried puting it between 2 books for several hours.... no help. Should I heat it up?
Old 02-07-2005 | 01:34 AM
Time Pilot's Avatar
Default RE: Slow stick elevator warped.... help!
If it wasn't bowed before you taped it, I'd consider untaping it and trying again. I've pulled tape off the wing before, and it pulls some of the paint off. I used a red acrylic paint to touch up the white spots. The elevator is a tad thinner.
If you're worried about damaging the foam, you can cut the tape and try again. Maybe the best solution.
I don't really recommend heating it up. I did this to my last SS fin to straighten it up after it had bowed and it didn't really work out as well as I had hoped. The tape will likely shrink a bit too, or stretch, if you heat and pull, but at a different rate than the foam...
Old 02-07-2005 | 01:54 AM
FlybyPDX's Avatar
It was bowed before I taped it..... [&:][&:][&:]
Old 02-07-2005 | 02:35 AM
Bill Adair's Avatar
Bummer PDX!
Will your hobby shop replace the elevator?
The hinge line must be straight, or it is likely to bind (as in your case).
Another solution that may work, is slicing the existing hinge tape between the surfaces, and using a few cloth figure eight hinges, with a little slack in them (to allow for the mis-matched surfaces).
Bill
Old 02-07-2005 | 08:16 AM
I would suggest gluing and taping a rod, preferably carbon fiber, to the leading edge of your wing. This will take the bow out of the foam and let the elevator move more smoothly while also adding some extra strength.
Old 02-07-2005 | 08:24 AM
Matt Kirsch's Avatar
My Feedback: (21)
Gentle and careful heating, while holding the elevator on a flat surface, will also straighten it right out. Finding carbon fiber is not always the easiest thing to do.
Old 02-07-2005 | 08:36 AM
ORIGINAL: FlybyPDX
Dare I ask what happened to the other two?
ORIGINAL: Matt Kirsch
If you have any fiberglass rod left over from the other builds, you could use that.
Old 02-07-2005 | 10:05 AM
GWR's Avatar
GWR
My Feedback: (31)
Leave it like it is; fly it, crash it, build another.
Old 02-07-2005 | 01:16 PM
What GWR says. It's only a Slow Stik.
Old 02-07-2005 | 02:04 PM
FlybyPDX's Avatar
ok.... I used tape to flex it straight. I still have the other 2 slow stoicks.
Old 02-08-2005 | 12:34 PM
My Feedback: (21)
Nicely done! There's always more than one way to skin a cat
