Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
 gws corsair electrics problem >
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 05-02-2005 | 12:50 PM
Default gws corsair electrics problem
I have recently bought a gws corsair complete with the motor, and i bought the battery, servos, reciever and speed controller separatly. I am using a futaba 6EXA radio, and the same crystals from my other plane in a jeti micro reciever. I find that when i connect the Nimh 8.4v 1050ma battery pack to the circuit, the speed controller (ripmax 12) gets very hot. the micro servos that i am using (hs 55's) are not responding to the radio, and i have no controll over the speed of the motor, but the motor does run.
Does anyone know if i am doing anything wrong, or if i am using the wrong equipment?
This is my first electric aircraft so any advice would be appreciated.
Old 05-02-2005 | 12:55 PM
vicman's Avatar
My Feedback: (10)
Default RE: gws corsair electrics problem
Do you have your battery connected to your speed controller plugged into the throttle chanel?
Old 05-02-2005 | 01:59 PM
yes, the battery is connected to the speed controller, and the speed controller is plugged into channel 3 in the reciever. Is it ok to use a 6 channel radio on a 4 channel reciever? and is the heat coming of the speed controller normal?
Old 05-03-2005 | 03:11 AM
I have it running ok now, turns out one of the wires was the wrong way round! But now the motor wont run steady, it will spin for a second, then stop, and it wont reach its peak rpm - I think this is because the battery isnt fully charged but how would i go about charging a nimh battery with a BEC plug on the end?
Old 05-03-2005 | 08:09 AM
Matt Kirsch's Avatar
My Feedback: (21)
You're lucky, or maybe not. Hooking up the wires the wrong way 'round generally causes the ESC to burn out. The erratic behaviour could be the result of a dead battery, or a burned out ESC.
To charge the battery, you'll need a peak detect battery charger, and a charge lead with the mate to that BEC connector. I don't know what's available to you in the UK for chargers, though...
