Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
more power
Old 06-07-2005 | 02:47 PM
Default more power
ELP ; HELP ; HELP
I HAVE A FOAMY GWS QUAD TRANSPORT, IT HAS NIMH AAA 750 MAH 8.4 V BATTERY.
MOTORS 4 GWS EDP 50 DIRECT DRIVE , ESC GWS ICS 300 8 AMP, RECIEVER FUTABA
114F.
HOW BIG A LI-POLY CAN I GO UP TO, NEED TO KNOW THE MAH AND VOLTS.
PLEASE PLEASE ANSWER
THANK YOU BILL
Old 06-07-2005 | 03:47 PM
Mike Parsons's Avatar
Default RE: more power
ORIGINAL: lillbill11
ELP ; HELP ; HELP
114F.
THANK YOU BILL
Bill,
You could replace the 8.4V with a 2cell 7.4 volt lithium. A 3 cell will burn out your motors in short order. If it were me, I would look at an Apogee 830 or Thunderpower 900. Unless you need the weight up front and then I would look at a 2S 1320 or 2S 1500. Note that the GWS Speed controllers do not have lithium support.
There is a pilot using a 2S Tanic 2500 in his with very good results.
-Mike
