Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Multiplex Twin Jet question
Old 07-29-2005 | 04:13 PM
Default Multiplex Twin Jet question
Just bought one of these complete with 2 400 motors. Built fine and fitted a 3000mh Nimh 9.6 pack and a 35A ESC. Problem is that it just won't get into the air! Simply flies in a downward direction and land about 20 feet away. Obviously I'm doing something wrong but any ideas?
Old 07-29-2005 | 05:55 PM
My Feedback: (314)
Default RE: Multiplex Twin Jet question
Does this plane use elevons? If it does, "reflex" the elevons. This simply means that you have to have some "up" all the time in the elevons. You'll have to adjust them. This should have been covered in the instructions.
Old 07-30-2005 | 02:39 AM
Yes it does use elevons. I'll give that a try.
Old 07-30-2005 | 05:42 PM
How much thrust do you have. Are your blades on the rght way eg push mode, is the motor running in the right direction, and have you checked your cg. You need to make sure you have elevator and aeleron mixing, eg Delta Wing.
Old 07-31-2005 | 01:12 PM
All sorted now. The problem was I wasn't chucking it hard and fast enough! Flying fine now.
Old 07-31-2005 | 02:39 PM
My Feedback: (314)
Glad to hear it. Enjoy the plane. I've seen videos and the ones I've seen are extremely fast and aerobatic.
Old 08-09-2005 | 07:33 PM
Go to www.rcflights.co.uk for video's on the TwinJet.
