Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
 problem with reciever, help!!!! >
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 09-28-2005 | 06:43 PM
Default problem with reciever, help!!!!
ok i have a gws r-4P|| /H 4 channel reciever. now its 1, 2,3, and then 4/b, now i thought u plug the esc/battery into the 4th channel and then the others into 1,2,3, but i plugged the 3 servos into channels 1-3 and a temp. battery into the 4th, it works but the rudder on channel 3 is being controlled by throttle movement. do i need the esc plugged in/lipo into channel 4 for it to work properly!? help!!!!! i wanna fly this thing already!
Old 09-28-2005 | 06:46 PM
Default RE: problem with reciever, help!!!!
If you have a Futaba or hitec radio the ESC goes into channel 3. For JR or Airtronics it will go into channel 1.
Old 09-28-2005 | 06:51 PM
I should add that channel 1 is aileron, 2 is elevator, and 4 is rudder on a Futaba/hitec radio. It sounds like that is what you have because of the rudder working with the throttle.
Old 09-28-2005 | 07:22 PM
right i have a futuba radio, but when i plugged my temp battery into channel 3, 1 and 2 worked but channel 4 didnt, so i need the esc/lipo for it to work?
Old 09-28-2005 | 09:13 PM
Yep, that should do it. Or its a bad receiver.
