Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Brushless or LiPo?
Old 03-22-2006 | 01:23 PM
Balsacutter's Avatar
Default Brushless or LiPo?
OK all you ePower gurus, say your whole electric fleet was still back at the Mabuchi Motor/Nicad powered stage when the wife approves some limited $$ for upgrades, but only enough to buy a brushless motor/ESC OR a Li-Poly battery/charger set.
If you could only pick one, which upgrade would you pick: replace a cheap brushed can motor with an outrunner, or start in with Li-Poly cells and a suitable charger?
(Say the target plane to be upgraded is a Mountain Models Switchback Sport with GWS EPS 300C and 8 cell 600 nicads, if we need to avoid the "well, it depends..." problem.)
- Norm from New England
Old 03-22-2006 | 01:42 PM
vicman's Avatar
My Feedback: (10)
Default RE: Brushless or LiPo?
First off GO BRUSHLESS!!! Without a question that is the best start. Now about that charging system and battery issue. I take it you are figuring about 100 bucks or so for the charger? Consider the Hobbico MKII for half that then you will still have enough $ for a 3s battery.
Old 03-22-2006 | 02:06 PM
rcboatnut's Avatar
If you upgrade to brushless motor first make sure the motor will run descent on the voltage of your battires, I upgraded to lipo first to get run time and then upgraded to brushless for more power and more run time.
Old 03-22-2006 | 02:20 PM
Either way is probably a wash. Brushless motor w/ESC is a little lighter, more efficiency. LiPo is a little lighter, same efficiency, but more capacity. However, if you go LiPo, you'll still either need a new ESC that can accomodate the LVC, or a LiPo saver. Given limited funds, you're probably better off going with the new motor.
