Mini Telemaster Mod
Hey,
I am think of making a mini telemaster as a camera plane. If dont already know, the mini telemaster is a 3 channel plane. I want to put ailerons on it.
There were two things that i was going to do.
1.) Full wing length ailerons.
2.) Reduce the dihedral from 7 degrees to about 3 degrees.
Will this work???
What rules/hints/tips must you do when transfer a plane from 3 channel to 4.
Cheers
Will this work???
Cheers
It will work. However, I'm not sure why you need to add ailerons in order to hang a camera on the Mini Telemaster. I have flown mine with two different cameras, one of which weighs abotu 250 grams, on the stock wing, and I don't think that having ailerons would present any real advantages on this design. Just my unsolicited opinion. It does seem to make a pretty good camera ship though.
edit: also, check over on wattflyer.com. IIRC, there was a Mini Telemaster build thread there a while back where the builder added ailerons. That should give you some useful info to get started.
