Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
Need Technical Speed Controller help >
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 01-12-2003 | 05:08 AM
Default Need Technical Speed Controller help
I have a blimp that uses a Jeti 180 speed controller w/bec and a tail fan controller that is reversible. \they both are tied into the same 1600mah 6 cell. When I use the tail motor and teh fans at the same time it is tripping the bec and turning off the main fans. Does anyone know if putting two speed controllers on the same battery is bad? would adding another cell help. (upping it to a 7 cel pack. )
thanks in advance for any advice
Old 01-13-2003 | 05:57 PM
Matt Kirsch's Avatar
My Feedback: (21)
What's happening is that you're drawing more current from the battery than it can comfortably produce. The voltage is dropping due to the excessive current draw, and causing the cutoff to activate.
Adding a 7th cell would only make the problem worse. Increasing voltage also increases the amount of current drawn by the motors.
The obvious solution is to get a battery that can handle the current. However, you may be using a propeller that is too large on these motors. What size motors and what size propellers are you using?
