Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
 blade cp electronics in a flatout? >
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 10-08-2006 | 02:49 PM
Default blade cp electronics in a flatout?
Will Blade CP electronics/battery work in a flatout? servos, receiver/speed control, radio, battery..? thanks
Old 10-08-2006 | 05:25 PM
Default RE: blade cp electronics in a flatout?
The Blade receiver is just a 6-channel. Hooked up to standard servos and ESC it should work OK.
There's mixing in the ESC part of the 4-in-1 that might make things operate oddly on a airplane.
And there's a built in gyro on the rudder channel, as well as an ESC for the tail rotor motor. You won't be using that in a Flatout.
Old 10-08-2006 | 05:44 PM
But I can just not connect the tail motor, right?
Old 10-08-2006 | 09:21 PM
There's nothing to connect it to on a Flatout. The output from the 4-in1 to the tail rotor motor is from the 2nd ESC in the 4-in-1, it's a varying voltage to a motor, not a signal to a servo
On the receiver when it's seperated from the 4-in1, channel 4 would connect directly to the rudder servo.
There's nothing useful in the seperated 4-in-1 ESC/gyro module for an airplane.
