Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
Converting Gee Bee Tiger Moth >
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 02-07-2002 | 08:00 AM
Default Converting Gee Bee Tiger Moth
Hi all,
This plane dry comes out at 27 ounces has a 45 inch wing span, 650 sq inches wing area. I want to make it electric what would you recommend for a motor and battery size.
Old 02-15-2002 | 02:52 AM
have absolutely no idea, but it's fun to finally find you some where on line , ole buddy!it's been to long since i have seen your smiling face!
Old 02-15-2002 | 11:37 AM
About time you came out of the woods Wing. How you be? Email me your phone number.
Old 02-21-2002 | 02:30 AM
Default gee bee electric
Hi there,
I saw one of these in S&E Modeler a few months back with an AstroFlight 805G brushless and 8 - 3000mAH Nickel Metal Hydride batteries. It claimed 12-15 min flights.
I think this sounds about right, maybe overkill.
Try this link for a good 8 cell motor controller:
http://www.modelairtech.com/combos.html
Belt drive, brushless..and reasonable. I am going this way next.
If you want to go cheaper, do an Endoplasm car motor, 8 cells and a Master Airscrew gearbox (you can get the Endo and the gearbox through Tower Hobbies).
Hope this helps.
I have a Thunder Tiger Lazy Cub that I am flying on 8 2000mAh cells and an MEC turbo 10 plus motor. This plane is for a 26 four stroke (like the GeeBee Tiger Moth) so I think it is about right. I think this setup is a bit overpriced based on what I am seeing out there.
Steve
[email protected]
Old 02-21-2002 | 08:41 AM
I've been looking at the Hacker B40-9S with 4.4.1 ratio and a 10x6 prop on 8 cells. Any experience with this set-up?
Old 02-21-2002 | 02:27 PM
I've not seen the Hacker setup. I have worked with Aveox motors before.
Where did you see the Hacker? Can you send me a link?
I have seen the hacker name show up often, I would like to check them out. Please let me know if you get this setup and how it works.
Steve
Old 02-22-2002 | 07:16 AM
Default hacker site
goto www.aero-model.com it will lead you to the motors.
