Twinstar II Lipo Battery confusion/decisions (3s 2500-3200 ideal) thoughts?
CA
RE: Twinstar II Lipo Battery confusion/decisions (3s 2500-3200 ideal) thoughts?
it is a GWS 2-3 cell lipo safe esc. When i first plugged the battery in polarity was wrong so i got a small spark, i then redid the deans on my battery and got now power, do you think i short circuited the esc that fast? and i never plugged in any motors just pluged the esc intho the throttle channel on my ar6100. Thanks
My Feedback: (9)
mtbrider,
If you checked out the previous points, and a fully loaded battery connected to your ESC and it still doesn't give any sign of life , then, most probably you destroyed the ESC with the wrong polarity connection of your battery.[]
Be carefull:
If you changed the Deans connector in polarity on your Lipo battery, be sure you have the right connection on your charger to !!
Be carefull:
CA
the lipo has different plug for charging, o well im gonna get a tool to see if i fried my esc, if i did 30 bucks down the drain , so far its been great tho for my first build. THE TWINSTAR II LOOKS AMAZING!!
CA
alright ran into another small problem, i was told by my lhs that a 3s 2100 will burn out my permax 400 6v motors very fast, will a 2s 1650 be enough power? or was my lhs wrong, thanks
My Feedback: (9)
mtbrider,
It's true that your Permax 400's will worn out quicker with 3S Lipo's, however you probably don't full throttle all the time with 3S. The cost of replacing 2 Permax 400's isn't that much compared to the price of another Lipo pack.
However It will shure fly with a 2S Lipo pack, depending on what kind of power You want from it.
Check out this site:
http://www.rcgroups.com/forums/showthread.php?t=413667
