Triton setup problem
Hello,
I have a problem charging my NiMh batteries, i have a Triton Charger and when i use the setups as explained in the manual my batteries dont last more than 1 minute.
I am trying to charge tis batteries:
Electrifly GPMP0106 - 8 Cell 9.6 V AAA, 650 mAh NiMH
I have this setup:
Bat Type: NiMH
NiMH Charge = 0.1 A
Safe timer = 60min
Temp Cutoff = 90F
peak delay = 5
delay between disc/chg = 20min
peak sensit = 5mV
NiMH Max chg input = 600mAh
top-off = 0.1A
I belive that this settings are wrong because the batteries are not properly chaged, what should i change???
Thanks.
Alfredo.
I have this setup:
Bat Type: NiMH
NiMH Charge = 0.1 A
Safe timer = 60min
Temp Cutoff = 90F
peak delay = 5
peak sensit = 5mV
top-off = 0.1A
Thanks.
Alfredo.
