Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
setup problem
Old 08-06-2007 | 12:58 PM
sokrdz's Avatar
Default setup problem
hi i have a question when i plug in all my servos and esc into my gws pico reciever i get power to the servos because i hear them turn on but i cant move them. can anyone help me figure this out.
Old 08-06-2007 | 01:43 PM
My Feedback: (8)
Default RE: setup problem
sounds like you might have the wrong crystal in your receiver?
Old 08-06-2007 | 02:01 PM
sokrdz's Avatar
i am 100% sure that u have the right crystal. unless gws but a wrong crystal in the channel i ordered.
Old 08-07-2007 | 10:24 AM
Is your RX the right "shift" for the TX. In other words if you have a Futaba TX, does the GWS RX have a big F on it? If it has a J on it it will not work because that is for a JR-Airtronics TX. Also have had some GWS RX with bad crystal plugs, try wiggleing it around and be sure to put a piece of masking tape over it so it cant come out.....
Good Luck
Bob
Also make sure the servo plugs are in the right way because they can be reversed and cause your problem
Old 08-08-2007 | 12:48 AM
are you sure you are looking at the same plane when you try to move the servos?
