Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
 How Important is Ventilation? Newbie >
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 08-29-2007 | 11:00 PM
Cashpoboy's Avatar
My Feedback: (7)
Default How Important is Ventilation? Newbie
I have a 2 meter powered glider with a cobalt 400 motor. I have a Electrifly C-30 Mini ESC in it with a 7 cell 1300 Nmh battery.
The battery and ESC are enclosed and the motor is hanging out in the breeze.
Here's the question: Where does most of the heat come from and what needs to be vented for cooling. I am not worried about the motor since it is hanging out front, but what about the battery and ESC. How much heat do they produce and what happens if they overheat.
I just want to be sure I don't cook something on the first flight.
Thanks for any help.
Old 08-30-2007 | 01:13 AM
jdetray's Avatar
Default RE: How Important is Ventilation? Newbie
The more current you ask the ESC to carry, the hotter it will get. And if you are using the BEC in the ESC to provide power for your receiver and servos, the number and type of servos also has an impact on the heat that will be produced by the ESC.
It's the same story with the battery. The more current you ask it to provide, the more it will heat up. I'm not familiar with the typical current demands for that motor in that type of plane, but my gut feeling is that your battery may have too little capacity (mAh). If so, it will have a short run time and will heat up faster than a battery with a larger capacity.
As a general rule, anytime you operate an ESC or battery (or a motor) near its limits, you run the risk of overheating. Good practice is to use a wattmeter to actually measure the current to learn if your components are being overstressed.
Hopefully, someone who knows more about your motor and plane can provide some specific advice.
- Jeff
Old 08-31-2007 | 11:19 PM
Its a powered glider.....The motor just needs to get you up there. Take it easy and you should be fine. What plane is it?
Old 09-01-2007 | 12:14 AM
Cashpoboy's Avatar
My Feedback: (7)
I'm not sure what model it is but it is similar to the Goldberg Gentle Lady. Thanks for the help.
