Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
 3500kv direct drive in cap 232 ? >
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 11-28-2007 | 04:40 AM
Crabstick's Avatar
Default 3500kv direct drive in cap 232 ?
i have here a 400 size 3500kv outrunner from my trex, and a 960mm wingspan cap232, I know some pushers run some similar kv motors with like a 4.75x4.75 prop and they scream, I wanted to try the same with the cap232..
any reason why i shouldnt and can anyone recommend any other props?
Old 11-29-2007 | 11:10 AM
Default RE: 3500kv direct drive in cap 232 ?
For an aerobatic plane you'd be better off to put the motor on a gearbox so you can use a bigger slow turning prop Try it in in a GWS gearbox. I use a Himax 2025 with a KV of 4200. The GWS drive is a called a C drive which is 12 teeth on the motor and 64 on the big gear. It swings a 10 to 11 in prop for lots of pulling power for vertical stuff. Hope this helps.
Old 11-29-2007 | 09:45 PM
Crabstick's Avatar
a GWS c drive... i will look into it, Cheers
