USING 2 BEC WITH 1 RECEIVER
QUESTION, HOW DO YOU USE 2 BEC, WITH ONE RECEIVER? I WOULD LIKE TO MAKE A SLOW FLYER TWIN BUT NEED HELP WITH 2 MOTORS 2 BEC, 1 RECEIVER, 1 BATTERY PACK. THIS QUESTION MAY HAVE ALREADY BEEN POSTED BUT DON,T KNOW. THANKS FOR READING THIS.
For brushless..
Connect the two ESCs with a Y-connector, plug that into the receiver channel.
Some folks disconnect one of the red wires in the cable from the ESC to the Y-connector.
The best way to do this is add a short... 3 inch or so.. ordinary extension harness with the red wire cut, instead of cutting the red wire in the original harness.
You don't have to repair the original harness when you need to use it somewhere else.
For brushed.... A single ESC can be used, if the power needed doesn't exceed its rating.
THANK YOU FOR YOUR HELP I NEEDED THAT. FOR A MOMENT I THOUGHT I WOULD HAVE TO SPEND MORE MONEY LOOKS LIKE I WILL BE SAVING SOME THANKS TO YOU AND TO MENTION THE OTHER READERS WHO TOOK TIME TO READ MY POST. HAVE A GOOD DAY, lmalone
