F-27C stryker landing gear ???
G-Day all
i recentley burned out my E-Flight 25 amp ESC in my stryker for god knows what reason but that it another story..
i replaced it with a 36 amp venom esc and now the motor is to slow to react it takes about one second for the motor to react and then it spins very slowley for another second or so then it completley stops for about half a second and then it finaly starts normaly i am confordent that there is nothing wrong with the ESC.does it react slowley because the esc is so much biger than it is suposed to be and is there any way to speed up the reaction time on it the reason i want to speed it up because i hand launch my stryker and dont like hand launching it with the prop spining and by the time i throw it and hit the throtle it has landed its self...
is there any way known of puting a landing gear in my stryker or some kind of trolley which stays on the ground but acts as a landing gear.i am desperate to fly any help would be great thanks
simmo
simmo
FL
RE: F-27C stryker landing gear ???
simmo, you may want to check to see if the esc is adjustable some motors require a different advance on the esc to perform correctly. That may be your problem, or you may have damaged the windings in the motor and are getting an intermittent short.
As for landing gear, check the Stryker forum in the Park Flyers section, all kinds of set ups for landing gear. From a buggy to even like I did on one, and installed retracts.
thanks Glacier Girl
retracts sound kool how much would that cost rouphley and soes it afect the flight "charictoristics if thats fhow you spell it lol"i dont thik i have damaged the windings but how can you damage them ?? i will check my esc settings that may be the problem
thanks again
happy flying
simmo
thanks again
happy flying
simmo
ORIGINAL: simmo8
...i recentley burned out my E-Flight 25 amp ESC in my stryker for god knows what reason but that it another story...
yea i will do
i know now that the esc was burned out from a very slight overload on the engine about 2 seconds of the prop not spinning
could that of damaged the windings in the engine
thanks for yaz help
thanks for yaz help
ORIGINAL: simmo8
yea i will do
thanks for yaz help
yea i will do
thanks for yaz help
ok i am prety sure my lipo is ok coz i have used it a few times since and no swelling or anything has happend
the moter never felt warm at all
it was an e-flight 25 amp esc
i will check with another motor hoapfully 2 mora
wats emf ?
thanks
wats emf ?
thanks
