Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
 'dry testing' brushless motors >
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 06-04-2008 | 12:57 PM
ron_van_sommeren's Avatar
Default 'dry testing' brushless motors
Goedendag
"Some of us may have run across a brushless motor that has questionable operation, perhaps after overheating it, or after crash damage. It may even have come from a swap shop. The question is "Do you want to connect it to an ESC" and risk possible damage to the ESC? ..."
Several simple test methods:
http://www.wattflyer.com/forums/showthread.php?t=35216
http://www.rcgroups.com/forums/showthread.php?t=240993
Vriendelijke groeten Ron van Sommeren
• brushless motor building tips & tricks
• diy brushless motor discussion group
• Drive Calculator download & discussion group
Old 06-04-2008 | 04:59 PM
Default RE: 'dry testing' brushless motors
Good info.
Do you know where to buy some stater plates, 80-90mm, 12 tooth?
Old 06-04-2008 | 05:21 PM
Not that size but www.gobrushless.com has 18pole 65mm stators. Stators that size will always have more than 12 poles, otherwise the teeth would get too massive:
http://www.gobrushless.com/shop/inde...=SC+65mmstator
110mm statorlaminations
http://www.rcgroups.com/forums/showthread.php?t=612543
Scorpion (via www.innov8tivedesigns.com ) will be producering +100mm stators later on.
