Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
 thrust angle for f4u electric >
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 05-23-2009 | 12:35 PM
Default thrust angle for f4u electric
do anyone know the correct thrust angle on a f4u corsair alfa model electric foamie.running a park 400 outrunner, 920 Kv 30a esc 2.4ghz receiver1300mah li-poly
Old 05-26-2009 | 06:15 PM
Matt Kirsch's Avatar
My Feedback: (21)
Default RE: thrust angle for f4u electric
Any thrust angle should be built in already. If you're looking at a firewall repair, the best place to start is straight-up, to 1 degree down and right.
Beyond that, thrust angle is a "try it and see what works best" thing. Go a little at a time, one washer's worth of down and/or right at a time. That way you won't change the flying characteristics enough to make the plane unflyable.
This is a normal process that competition pilots go through fine-tuning their airplanes, one of the steps of trimming (not adjusting the tabs on your transmitter, really trimming the plane to fly well by adjusting balance and angles).
