Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Weight vs. thrust question
Old 03-02-2010 | 08:24 AM
Default Weight vs. thrust question
I know this has been asked a million times but i have a 16 3/4 oz. model with an estamated 15oz. of thrust am i good for spirited sport flying?
KZ
Old 03-02-2010 | 11:26 AM
tIANci's Avatar
Default RE: Weight vs. thrust question
What sort of a plane is it? Generally, it should be okay but do not expect great verticals.
Old 03-02-2010 | 11:53 AM
Its a 60% copy of GP Dazzler
It was 15oz RTF but i needed to add the extra weight to get the CG right. the battery (3s 850) is in the front compartment in hine sight i should have made the front of the fuse about 3/4 to an inch longer i think i could then move the motor and battery out more and it would have balanced.I could run a gws9050 and get 18oz but i'd be on the edge of 10amps at 9.5 so i'll try the 8040 and see what happens.
Here's a pic.
Old 03-02-2010 | 09:21 PM
cyclops2's Avatar
Once you are moving in the air you will be fine. NO prop hanging. Not enough to stop in reverse.
Enjoy.
