Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
charging amp
Old 05-10-2010 | 06:07 PM
Default charging amp
could some one help me here a 11.1 1500 pack should be charged at 1.5 amps. but will it hurt to make it 2.0 or 2.5 amps.i dont feel like waiting all day and i have a 7 amp charger.?
Old 05-11-2010 | 08:12 AM
Default RE: charging amp
If you want the most out of that battery, do the first charge or two at 0.1C for 16 hours. I assume this is a Nixx type battery, if not ignore the advice.
Old 05-11-2010 | 10:31 AM
jdetray's Avatar
ORIGINAL: sohigh89
could some one help me here a 11.1 1500 pack should be charged at 1.5 amps. but will it hurt to make it 2.0 or 2.5 amps .i dont feel like waiting all day and i have a 7 amp charger.?
At 1C, it should take less than an hour and a half to charge the battery. If it is really taking "all day," then something is wrong with either the battery or your charger.
It sounds like this is a lipo pack. Unless the manufacturer specifically states that it can be charged at more than 1C (1.5A), you are taking a risk by charging at a higher rate. There are some lipos designed to be charged at higher rates; you might want to get one of them.
- Jeff
Old 05-13-2010 | 04:40 AM
ok thanks for the help .ill just stick to the 1.5 amps.
