Need help with CC160 hv
Need some help with my new CC 160Hv esc
As soon as I connect my 10s or 12s power,the esc beeps the appropriate times and that's it. Example,10 beeps to recognize the 10 cell and then silence. The esc is flashing red constantly. What am I doing wrong? I've tried adjusting the throttle. Thanks for your input. Doug |
RE: Need help with CC160 hv
If your radio is a futaba, you need to reverse the throttle.
Thanks,did that, I am running twin fans on my F4,one works one doesn't,even when I disconnect the esc that works (right side) same result.
Also hooked the good one (esc) to the left fan/motor it works fine, so I know the fans are good. |
You seem to be trying to run 2 EDF fans from one ESC. You can't do that. they each ahve to have their own ESC. The TWOEsc's then get whyed to the RX. You know that you require a separate Bec/Rx battery to run the RX here. The CC has no Bec built in. The flashing sounds like the Rx is telling you its not getting a signal thru the esc. FWIWflytreetimes .
| All times are GMT -8. The time now is 10:20 AM. |
