RCU Forums
-   Electric General Discussion (https://www.rcuniverse.com/forum/electric-general-discussion-106/)
-   -   Battery Hold-downs? (https://www.rcuniverse.com/forum/electric-general-discussion-106/10878285-battery-hold-downs.html)
Balsacutter 12-27-2011 12:16 PM
Battery Hold-downs?
Building my first .40-size electric after a life in glo and parkflyers. How do you guys hold down big flight batteries inside airframes? I always used velcro for my little 3S/2200-sized lipos, but what techniques do people use to keep these 14-16 oz batteries from exiting the fuse? Will a strip of velcro still do an adequate job?
hyper701 12-27-2011 02:35 PM
RE: Battery Hold-downs?
I just wack a zip tie around the battery aswell as valcro, works for me.
Flypaper 2 12-31-2011 09:01 AM
Same as Hyper here.
gyrocptr 12-31-2011 11:21 AM
(duplicate)
gyrocptr 12-31-2011 11:22 AM
anti-slip carpet tape on battery + hook-and-loop strap (strap with hook on one side and loop on other side) wrapped around the battery and a suitable hold-down in the airframe.
Both materials available at Walmart.
Balsacutter 12-31-2011 11:33 AM
Thanks guys. I like the carpet tape idea. Hook and Loop strap, you mean a couple of those cloth straps that doubles over through a slot at one end, and holds the tail down with velcro-type stuff? I'd really prefer a rig like that than having to pry the battery off a patch of velcro each time I charge.
- Norm
gyrocptr 01-01-2012 09:41 AM
ORIGINAL: Balsacutter
...cloth straps that doubles over through a slot at one end, and holds the tail down with velcro-type stuff? ....
Yes.
Also available in bulk rolls that you can cut to desired length (no "slots", make/attach your own slot/ring if you wish). Strap has continuous hook-material on one side and continuous loop-material on the opposite side.
pilotpete2 01-01-2012 02:44 PM
Velcro "One Wrap";)
I have a 12' roll from Homer Depot. Countless uses!
Pete
fmw 01-19-2012 08:08 AM
Velcro
