How to setup speed controller?
Hi I'm newbie and I have
Watttage IC-15a Speed control and wattage crazy max powerset (370 motor, 3.67 gb/pro) For batteries 6C 800mAH 5/4AAA NiMh My goal is to put it on an 8 to 10 oz EPS flying wing Hobbypeople.net recommends this setup. The wires are huge on the speed controller- whats up with that? I'm going for lighter here - the 370 has thin wires- is there a speed controller to match? One servo plug comes out of the speed controller and gives receiver power- how does speed controller connect to recievers channel 3? Are any diagrams availble that show this? |
The speed controller servo plug goes into channel 3 and provides both power and throttle control. The power to the Rx can come into any one of the sockets.
Steve |
Steve is correct on the throttle channel #3 according to your receiver, do not put it in the B/5.
On my Jeti 110, the yellow wires goes to motor-Receiver wire from ESC goes in #3 throttle on Rx-then +&- according to polarity. This is on the Hitec Micro 555 receiver now keep this in mind. Check polarity of servo wire into receiver too. |
For the other part of your question - the ESC is good for 15 amps and has wires sized accordingly. Sounds like a lot of ESC for your application.
| All times are GMT -8. The time now is 11:56 AM. |
