RCU Forums
-   Electric General Discussion (https://www.rcuniverse.com/forum/electric-general-discussion-106/)
-   -   Need help to ID an ESC (https://www.rcuniverse.com/forum/electric-general-discussion-106/3354549-need-help-id-esc.html)
taker 09-13-2005 09:49 AM
1 Attachment(s)
I need to figure out what this speed control is and how to wire it.
There is a extra orange wire and I don't know where to put it.
I know there is two red and black wire sets Battery in and out.
There is a red and blue wire set I think this is for a switch.
Then the receiver connector.
Look at the pics.
Please help.
Thank you
Matt Kirsch 09-16-2005 07:19 PM
RE: Need help to ID an ESC
That appears to be a dual-ESC board out of a micro electric helicopter, such as an Ikarus Piccolo. The extra orange wire is almost certainly the tail rotor control wire. Since weight is a serious issue with these little buggers, and the power (red) and ground (brown) wires would be redundant, they only provide the signal wire.
It has two outputs, one black/red for the main rotor, and the other black/blue for the tail rotor.
taker 09-17-2005 01:11 PM
THANK YOU FOR GETTING ME AN ANSWER
I did some checking and you are right. It is for a Cupid Helicopter.
Small two channel copter that has a dual motor and a single speed control
THANKS AGAIN!!!!:D
