Basic parts help
I am fairly new to the sport of electric airplanes and I am hooked. I bought basic kit and now need some additional parts , I have listed what the manufacturer says I need. I want to go brushless, keep the same weight or go lighter, and faster, what parts should I get and where should I look for them at?
1. Speed 400 direct drive eletric motor. 2. 2 servos - 9 gram max weight & a torque rating of no less that 11 ounces per square inch. 3. 15A micro Eletronic Speed Controller. 4. I currently have a Hitec Neon SS radio, where can I get just the receiver so I can use the same radio? |
RE: Basic parts help
I CAN'T HELP YOU MUCH BUT SERVOS ARE RATED IN INCH OUNCE NOT OUNCES PER SQUARE INCH. IN. OZ. OR FT. LBS. FOR EXAMPLE ARE A MEASURE OF TORQUE. THE OTHER RATING IS THE SPEED THE SERVO MOVES TO FULL THROW FROM NEUTRAL AT A GIVEN VOLTAGE.
SORRY I CANT HELP YOU MORE THAN THAT GOOD LUCK |
You seem to have enough internet knowlege to post a message here, so maybe you should try a Google search on things like "400 speed motor" or "micro servo"
Sites to try are Hobby Lobby, Tower Hobbies, Hitec, and other forums here at RCU, like "electric planes" |
Check out the Balsa Products BP 21 brushless motor and the speed controller that goes with it. The one I have works very well. Not high quality but is reliable. Bluebird servos, BMS 306 work very well. This system will cover a lot of the more popular size planes. Have fun :D
| All times are GMT -8. The time now is 11:20 AM. |
