RCU Forums
-   Electric General Discussion (https://www.rcuniverse.com/forum/electric-general-discussion-106/)
-   -   motor problems (https://www.rcuniverse.com/forum/electric-general-discussion-106/6292338-motor-problems.html)
ankurkaul17 08-27-2007 06:43 AM
motor problems
hey friends...i m new to aeromodelling...i live in india...wen i connected my esc to my motor it didnt turn at all..so i used servo reversing on my tx...and wen i throttled up i heard a beep...but no turning of the motor...after a little more throttling the beep grew in shrill...and i saw smoke coming out of my battery terminal...plz help..wat could b the prob..why the motors not turning????
motor is a speed 400 8.4 v can type
esc is from world models....wm7020 15 amp continous current
i would b thankful to all those who help
Ankur Kaul
Matt Kirsch 08-27-2007 07:02 AM
RE: motor problems
Several possibilities:
1. Bad motor.
2. Motor is connected to the battery end of the ESC.
3. Battery polarity is reversed.
4. Bad ESC.
Walt Thyng 08-27-2007 07:35 AM
RE: motor problems
On some escs you have to retrun the throttle sitck to the off position after the initial beep.
WT
pilotpete2 08-27-2007 08:38 AM
RE: motor problems
The motor you are using sounds like a brushed can motor, could you post a link to the speed controller you are using, I could not find a listing for the model you mentioned. Are you sure the ESC is for a brushed motor? you can't use a brushless controller for a brushed motor.
Pete
ankurkaul17 08-28-2007 10:15 AM
RE: motor problems
u should find the link at pete..
and i know the polarity was correctly joined and the esc is for brushed motor only..i m sure....thankyou for ur replies friends
also wat measures can i use for reducing the motor vibrations...i m making a 37" foam plane
