RCU Forums
-   Electric General Discussion (https://www.rcuniverse.com/forum/electric-general-discussion-106/)
-   -   Pull-Pull or Push Pull? (https://www.rcuniverse.com/forum/electric-general-discussion-106/6865425-pull-pull-push-pull.html)
wings 540 01-06-2008 07:50 PM
Quick question, I just got an e-flite BYP YAK for my B-Day :D and the manual says to rig a Pull-Pull system on the rudder, and elevator. My question is should I go with the pull-pull or a push-pull system? any advice is helpful!
Thanks!
Red Scholefield 01-06-2008 07:59 PM
RE: Pull-Pull or Push Pull?
1 Attachment(s)
IMHO on small models pull-pull gives you much more positive control and at a lower weight. Of course this depends a great deal on setting up a pull pull system. My Tantrum has been flying with pull-pull (per design) on rudder and elevator for four years with no problems.
Tall Paul 01-06-2008 08:35 PM
The Byp-Yak system works very well!
And when the plane disintegrates (as it will), it's easily transferable to the next one.
cyclops2 01-07-2008 07:37 PM
What is the difference between the 2 ? I use 4# fish line snugged up between the servo arm and a same sized arm in the tail surface.
Since the lines are both snug, I call it pull-pull.
wings 540 01-08-2008 07:33 PM
Yep you can, the difference is that a push-pull uses one arm to control the surface, and the other uses two cords.
E-Challenged 01-14-2008 01:59 PM
I have had Dubro micro pull-pull thread go slack. If you use pull-pull system, use Spider Wire or other "no-stretch"cord and EX connectors with tiny cotter pins or fish hooks with hooks cut off to give you some adjustment. I use small aluminum tubing squashed to terminate cords.
cyclops2 01-14-2008 02:27 PM
I use 4# Nylon fish line with a ounce or 2 of tension. NEVER has gone slack on any plane. A 1/4 of a drop of CA on the servo control arm line hole does it.
DO NOT let the CA run alomg the arm and into the bearing.
cyclops2 01-14-2008 02:30 PM
I am going with the GWS push - pull stuff on a P-51. Full length tubes & secure wire & holes.
Little planes are a bother with P - P.
