Prop adapter problem.
I have just realized that I can not find a ready made adaptor to run my GWS 3 mm props on a 3.2 mm smooth shaft. I am now faced with a risky boring out of any 3 mm GWS prop...... to a hole of 5 mm. I can drill well. But this is a Russian Roulette job. :eek: Thanks for any sources. Rich |
RE: Prop adapter problem.
Get yourself a prop reamer. After all all you need is slightly larger then you now have.
I've never been able to find a prop reamer small enough for these small props.
I use a drill press, a careful eye, and progressively larger bit sizes so it's easier to center the bit. I also have a set of these metric drill bits: http://www.grizzly.com/products/G9753 which have been helpful. |
Thanks guys. The drill press wins. Rich |
| All times are GMT -8. The time now is 04:38 AM. |
