Air Hogs Aero Ace!
#6651
WV
RE: Air Hogs Aero Ace!
If anyone cares here are 2 vids of my modded Rolling fury, daytime http://youtube.com/watch?v=452XEnP-294 night time http://www.youtube.com/watch?v=yZuZMXyqMvY
#6653
WV
Thanks. This plane is becoming my fave out of the AH. Take the wing slats off and its a jet, put them back and its lofty and acrobatic. I also replaced the Tx antena with one twice as long and the responce time went way up. It flew like a new plane.
#6655
CA
Good looking bird Garrett. Deltas are a bit different to fly aren't they. Did you do the turn mod on your fury? It's getting to the time of year that I can fly until nearly 10p, so I may have to get mine squared away.
Ron, yes the motors in the cessna get weak over time. I think that's what's wrong with mine, I'm just not inspired to replace it right now. I use a quick disconnect on mine, but I don't know where to send you to get a tiny one like mine. I bought a bunch back in the hard core aa days from Tony.
Tim
Tim
#6656
WV
The only thing i did to the controller was long antena and glued tube over the buttons. Is there a turn without throttle mud for this tx? i havent found one yet.
#6658
CA
Garret the tube is what I was refering to.
Ron, a small drop of oil may help, try to find some with teflon in it, same as the aces. A new motor is about $10.
Tim
Tim
#6660
WV
Alright, im trying to make a plane from some stuff i got around the house. I had a walkera 22e heli that is junk now but the electronics are good. I need to know of a cheap rx and esc because this one has the servo mixing and i cant get 2 servos to work independently. I hope to use one of the motors from the heli, the main one is 380 i belive but im not sure what the tail rotor one is. Any advice would be helpful.
#6661
WV
I heard about this on the radio today and thought everyone would enjoy it [X(] http://youtube.com/watch?v=bEXxkWXncuo
#6662
CA
Ron, Yes you have to cut the tape and open the body, unless you can use a needle and put the drop on the shaft. But if you still have a slacker motor, you'll have to replace it. If you get that far let me know.
Tim
Tim
#6663
CA
CA
Ron, here's a link to the dev's thread. It's a decent little bird, pretty fast and if you do Lee's mods it is supposed to be a blast. http://www.rcgroups.com/forums/showthread.php?t=716568
Tim
Tim
#6670
WV
Just got back from radio shack with 5 star screams . Does anyone know what size lipo is in it, ive yet to tear one apart. I plan on making a PBF out of one.
#6671
CA
Garrett, check the thread linked to above. But I think I remember it being a 200mah. Also if you haven't had one there is a trick with the controller that switches it from novice to pro.
Tim
Tim
#6672
The trick is hold left(right gives intermediate mode.) while turning the tx on.
The lipo is a 130mah.
The firewing is a new airhogs plane with leds and a 49mhz tx..... it has a all or nothing throttle...... the motor is a single aa prop... it is small..... and has a horizontal protecting ring around the prop...look for elliptical wings and black or white (both with flames) color schemes.
#6673
OH
ORIGINAL: Garrett1234567
Chris
#6675
WV
Thanks Chris, i'll have to try that when i get home. Ive been at the inlaws all weekend.
Take some tubing, i run nitro trucks so i took fuel tube, cut 1/8 in pieces and glue them
over the buttons on the right stick. This will give you elevon control while turning. If you
find a turn without throttle mod please post it for me
