Smart Aero Ace
UT
Smart Aero Ace
This is really weird, I was flying my AA in a field behind my house, and the wind picked up, so I decided to push its limits, then it flew away. So I went home devestated[&o], only to find it upside down on my roof!
How random was that, with no damage too!
WA
RE: Smart Aero Ace
dang man you got lucky me and my cusin where flying mine and the wind picked up so i told my cusin to bring it down it the wind took it up up up and away dont know where it went im going ot get another today thats awesome thoe have fun
UT
RE: Smart Aero Ace
Ive got a dying question, Do you think its possible to get working contorl surfaces on this thing, Prolly have to use thoes Bluebird microservos. But then it would need more power, so mant loopholes
TX
RE: Smart Aero Ace
schun007,
there is a mod you can do to add an actuator so you could have a rudder, but thats it. its a pretty easy mod if you know how to wind your actuator or already have one. you just solder one of the leads from the actuator to the Positive lead of the left motor, then solder the other lead from the actuator to the Positive lead of the right motor. i dont think the AA would like the weight of BlueBird servos, they're relatively light, but its still extra weight (not sure if the motor outputs could drive a servo either). actuators can be made incredibly light, and you can now buy ones that are very light too.
i've done this mod on one of my planes and it worked well. there is a catch though: since the actuator is connected to the motor leads, it means the actuator is getting power at all times, which means more drain from the battery and shorter flight times. if you have a high Ohm coil (200 or higher would be good probably), the current drain probably wouldnt be too bad.
nick
nick
RE: Smart Aero Ace
ORIGINAL: motormat
dang man you got lucky me and my cusin where flying mine and the wind picked up so i told my cusin to bring it down it the wind took it up up up and away dont know where it went...
WA
RE: Smart Aero Ace
ne it was at my cuzins house we checked his house but no luck it might be on the back side of the house we thuink it landed on i bout another one thoe got money for x mas lol well thanx for the advicee
