Electric Indoor & Micro RC Flight Talk about this fast growing niche in rc. Micro radios, micro electric or co2 powered planes, heli's both indoors and out.
Air Hog AA Kitbashing
Old 02-23-2007 | 10:35 AM
}---O---{'s Avatar
Default Air Hog AA Kitbashing
I would like to hear from the kitbashers....What mods have you done?
Old 02-23-2007 | 10:52 AM
Neurotex's Avatar
Default RE: Air Hog AA Kitbashing
Kitbashing and building your own plane from scratch is the most
rewarding part of the hobby.
Some examples are shown here:
[link=http://www.rcuniverse.com/forum/m_5244036/tm.htm]aa mods[/link]
I've been working on a blog for the AA that will go into some detail as to
how to build peanut sized RC AA's. It should be up in about a month, just
in time for the summer flying season.
Old 02-23-2007 | 04:40 PM
}---O---{'s Avatar
I am looking forward to seeing it. I just started with this stuff and am amazed at what one can do with them. I am an electronic tech and can't wait to start modifying these planes. I guess the sky is the limit.
Old 02-23-2007 | 06:13 PM
flyace's Avatar
heliwabbit are you getting an AA?
Old 02-23-2007 | 06:18 PM
}---O---{'s Avatar
We will work on that!!
Old 02-23-2007 | 07:01 PM
flyace's Avatar
heliwabbit i guess its not kitbashing but i cut up two paper plates and taped them to my AA bipe. i would tell you how it flies but i'm having trobble with my left moter.
Old 02-23-2007 | 07:40 PM
}---O---{'s Avatar
Like I said, the only way to know is to check and see if the motor is getting power or binding.
Old 02-23-2007 | 08:29 PM
flyace's Avatar
i tried it with the plates, don't do it!!
Old 02-24-2007 | 05:10 AM
andrewtexas123's Avatar
Is there any hair stuck on the motor shaft?
Old 02-24-2007 | 07:32 AM
flyace's Avatar
no.
Old 02-24-2007 | 08:38 AM
}---O---{'s Avatar
Can someone tell me what motor is on the AH BiPes?
Old 02-24-2007 | 09:56 AM
Neurotex's Avatar
ORIGINAL: heliwabbit
5.3 ohm 6mm coreless -390mA draw per motor
flyace, you might be in the early stages of a fried RX.
I feel like the town crier, or better yet, a broken record. But if
it's not the motor, gunked prop, stuck prop.... & on & on...
then the RX is failing and soon the motor won't turn at all.
Old 02-24-2007 | 10:35 AM
}---O---{'s Avatar
I live close to flyace and will be able to see what the issue is on monday.
Thanks for the specs on the motors. I will be looking to upgrade them soon. I'm going to try to drop the mA draw while increasing prop speed and maybe adding a coil or cap to smooth out the motors. Who knows...
I must play....
Old 02-24-2007 | 12:07 PM
Neurotex's Avatar
I must play....
If it is a burnt RX there is a fix for it. Mosfets can be soldered in place
of the failed transistors and can increase the current draw up to 4.3A's.
flyace can be back in business in no time and run larger motors to boot.
http://www.falcon1.net/~ars/rcmodels.html
Old 02-24-2007 | 04:56 PM
flyace's Avatar
sorry for the mix up but i guess its working now.
Old 02-25-2007 | 06:26 PM
}---O---{'s Avatar
Sounds like the 3-1 oil workrd it's way into the motor.
Old 03-01-2007 | 11:12 AM
}---O---{'s Avatar
What is the "Best" micro flyer on the market....now?
Old 03-04-2007 | 05:19 PM
flyace's Avatar
the picco z!
