MicroGear Ecoman (Havoc/PicoZ) Heli REPAIRS!
TX
Edited now to list some repairs I have done;
I have the MicroGear Ecoman Heli from FRY's and I am new to this forum. I came here looking for help after having to perform repeated repairs, and now see tons of mods, suggestions , excellent pics....so I just wanted to add a simple thread for things I have noticed. These are the relatively simple things to check if you are having heli problems.
Hopefully this will help any (fellow) newbs.
Wobbles
1) Check hair/debris caught in tail or main rotot shafts. Easily removed.
2) Check loosness of main stabilizer blade. I lost the top cotter pin and had to twist 3 very small staples together to create a replacement cotterpin, bending the ends around and clipping.
3) Check weights under stabilizer blades. Mine lost them on one side and had to be super-glued back in.
4) Check main rotor shaft.
Lack of power
1) Check battery power in recharge unit. Need good batteries.
Wobbles
Lack of power
RE: MicroGear Ecoman (Havoc/PicoZ) Heli REPAIRS!
Xanthius
You shouldn't have too much trouble with this heli. I purchased 6 from Fry's and am still on the first one and fly it multiple times daily. The power is awesome compared to the Havoc/PZ. I've just started doing hot laps with it around my living room and am up to 62 so far on a single charge. If you reinforce the tail rotor blades with epoxy you should have a machine that is practically indestructible.
Cheers!
Cheers!
My luck just ran out!
Was on lap 72 when I struck a ceiling fan chain and knocked a chunk out of my main rotor! Seemed to have alot of charge left so I'm now real curious just how many hot laps a guy can get out of one of these.
Stay tuned.
Stay tuned.
TX
I got wobble that won't go away.
Not sure where it's coming from, but I plan on replacing my main rotor as soon as it comes in, as it started this wobble after my cotter pin flew out. My 3 twisted staples look very sturdy and well placed, but I suspect there is some slight looseness still there.
Will update when replaced.
TX
Decided to post something I noticed.
With short bursts of thrust , then letting the blades settle, you can check your balance. I found that the weights I had replaced were lighter than the other side, so I am in the process of balancing my blades.
Hopefully THAT will get rid of the wobble I am seeing.
IL
I got a terrible wobble too - it threw a weight and now after gluing it's still bad. any help would be great
IL
Well I used your short burst method and saw the side with the weight that I re-epoxied in was still lighter than the other side that i just put a dab of epoxy on so it would have more holding it down. It was off so much that I took an automotive fuse; cut off one of the 2 prongs (chysler type) and taped that to the top of the blade. It was about the same size as the weight below and it seems to have balanced it a lot better. More testing is needed and I can't believe that it needed that much EXTRA weight on that side.
IL
Well I got a great tip on balancing. To use blu tac. I just had a bottle of white out that spilled awhile ago and when I picked it up - it was stuck to my desk. I got it free and the stuff I scraped up off the desk was like the clay stuff called blu tac. I used it on the fairy where the added weight was and it did the trick. I dremmeled a little on the other side so I didn't need to put on too much of the dried white out. It was like clay - just tear off a little and roll it on your fingers and then press on to the rotor. worked great - nicely balanced.
TX
hey dudes, dont double post some people will curse you out for it. i dont mind it but im just trying to save you all the trouble.
