Go Back  RCU Forums > Electric Aircraft Universe > Electric Indoor & Micro RC Flight
 Millenium PTU rotor replacement procedure >
Electric Indoor & Micro RC Flight Talk about this fast growing niche in rc. Micro radios, micro electric or co2 powered planes, heli's both indoors and out.
Old 11-06-2007 | 10:55 AM
My Feedback: (77)
Default Millenium PTU rotor replacement procedure
Hello,
Could somebody give instructions for replacing the Millenium PTU main rotor? It seems that it is pressure fitted onto the main shaft and a bit delicate to take off.
Teryn
Old 12-28-2007 | 11:59 PM
Default RE: Millenium PTU rotor replacement procedure
We found that the old one can be removed by grasping it with one hand while grasping the gear on either side of the body with the other hand, and then gently twisting while pulling. We replaced it with another one (from a PTU that needed some repairs) and held it in place with a drop of CA glue. So far, it has worked.
