Almost Ready - GeeBee Z
1 Attachment(s)
Here's the latest pic's of my indoor GeeBee Z, lacking only the canopy, almost ready to go. (There's no tailskid, either, but that's okay - the wheels are going to have to come off for flight anyway I'm afraid).
I'm also waiting for a calm, dry day, too. At its present weight of 50g, the first flights had better be outdoors I'm supposing. I may even need to up the motor and prop size, too. |
RE: Almost Ready - GeeBee Z
That looks very good, Dan. How about shooting it on a neutral background so that nice job doesn't get lost in the backgound? How long before you get some flight tests?
Dan,
Excellent job on the airframe. I hope she flies well for ya! Just a little advise, the folder prop and KP00 is very inefficient setup. You won't get the max thrust the KP00 can output with that prop. The U80 is better and a GWS 3X3 is even better. |
Hey Dan,
How does the GWS 3x3 perform on a Kenway geared M20? I have this setup on a Lil'Skeeter, but won't be able to test until Wed. night. |
Nice looking micro BykrDan. Where about in Ohio are you?
Thanks guys... Excellent advice, I will take it all.
I had to mess with the pictures quite a bit to get even that much yellow out of them! I'll just take it outside or something and get better pictures. Thanks for the tip about the prop - I'll need all the power I can get out of this setup to fly this plane. I just stuck the folder on because it seemed to clear the cowl better, but I think I'll look up the 3x3. If I have a lot of trouble, I'll try the 4.2:1 gearing and the 10cm prop... I'm finishing the mold for the canopy tonight, so I may be able to get a test flight in this week, if the wind stays down. By the way, Mike, I never did see a flight report for the Albatross - did I miss it? Tiberius - I'm in West Chester, some minutes toward the frozen north of Cincinnati. Pronounced 'Cold'n'Windy'. Dan. |
ORIGINAL: BykrDan Tiberius - I'm in West Chester, some minutes toward the frozen north of Cincinnati. Pronounced 'Cold'n'Windy'. Dan. |
tiberius,
The 3x3 would be too small for the 4.2:1 gearing. Try a 4X4 or maybe a 5xwhateverthesmallestgwspitchisfora5"prop. |
Dan,
I've flown it, but just a few short hops. I'm trying to get 1) a day away from work, 2) no wind, 3) a decently smooth surface, and 4) a photographer together at the same time... In the short hops I've made, it does ROG and fly, and the controls seem to be adequate (roll rate could be a little faster, though). I do have some serious questions about the MJ Rx's range, so I'm sort of afraid to fly it outside. I'm hoping to take it and another one in the works to the next indoor meet so I can get 1 through 4 together in a space where I won't get out of range... |
| All times are GMT -8. The time now is 02:29 PM. |
