RCU Forums
-   Electric Indoor & Micro RC Flight (https://www.rcuniverse.com/forum/electric-indoor-micro-rc-flight-182/)
-   -   Helium (https://www.rcuniverse.com/forum/electric-indoor-micro-rc-flight-182/633141-helium.html)
jabs130 03-18-2003 10:31 PM
Helium
I was thinking about it. if you build a small plane but find that it woun't fly try this. Put helium in the wing cavity. you have to make sure that it is airtight, with the exception of two rubber pump holes, on oppasite sides. Like the type of a basketball. tilt the plane on its side. tkae the helium pump and pump the heluim in to the top hole. meanwhill but a holow pin on the bottom hole to let air out. you need to find a heluim pump somewhere. not sure where but i have seen them. I you make it airtight the helium shoudl stay in for a while.
And ideas on this?
Alex
P.S. desighing my elevation conrtol will be here soon
Steve Lewin 03-19-2003 10:40 AM
Helium
If you check you'll find that the volume of helium in the average small wing would reduce the overall weight by about 2 or 3g (or less than the weight of the valves you'd need). Helium needs a LOT of volume to carry any payload.
Steve
Diesel Dave-RCU 03-19-2003 11:42 AM
helium
I happen to play with a rather large indoor blimp from time to time. Helium will lift just under an ounce, per cubic foot. Given that, I really don't think filling the wing of an indoor flyer, will do you any good.
Helium is an atmospheric gas, I have never seen a "pump" for it. But that is not to say one exists. Compressed tanks are readily available.
Dave
jabs130 03-19-2003 09:23 PM
Helium
just pondering it. thanks for your imput
wild3dfunfly 03-30-2003 04:52 AM
Helium
maybe blow up wings ?
