Multiplex 4260 620 motor
Not needed.
NEW IN THE BOX WITH ALL THE HARDWERE.
GERMAN MADE.
Perfect for 4,4 lb ( 2kg) 3D model or 14,3 lb (6.5kg) glider
Diameter 42mm
Length 46mm
Weight 205g
Max output 680w
Max Rotional Speed 12.000 Umin
Max Case temperture 65 0c
Mounting 0 25mm 4 x M3 (5mm Deep)
RPM / V 620
Lipo 3 - 5S
Optimum Working Range 25A - 40A
Max. current for 15sec 53A
Shaft 5mm
100usd + shipping.
GERMAN MADE.
Diameter 42mm
Length 46mm
Weight 205g
Max output 680w
RPM / V 620
Lipo 3 - 5S
Shaft 5mm
100usd + shipping.
