Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
Reload this Page >
Extreme Flight Vanquish 2m Build Thread
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 05-18-2013, 01:35 PM
  #1476
STEVE HOSNER
Default RE: Extreme Flight Vanquish 2m Build Thread
Nick,
I have had zero problems with the hinges included with the kit. All and all I think the Vanquish is a great plane.
Steve Hosner
Old 05-18-2013, 02:54 PM
  #1477
nosram
Steve,
Thank you, that is great news. Did you also gap seal with Blenderm tape?
Thanks, Nick
Old 05-18-2013, 06:31 PM
  #1478
STEVE HOSNER
Nick,
On my first Vanquish (Yellow and Red) I used Blenderm and on my second Vanquish(Blue and Pink) I used white Econo Cote to seal the gaps.
Enjoy your build you will love this plane.
Steve
Old 05-24-2013, 06:03 AM
  #1479
vatechguy3
what is the stock tire size??
when you gues measure balance, i am assuming the 7-1/8" is at the root?
thanks
tony
Old 05-26-2013, 11:49 AM
  #1480
vatechguy3
Talking to some guys at my field, do I need a spark arrestor to avoid sparks when plugging in the batteries??
Tony
Old 05-26-2013, 12:29 PM
  #1481
rightflyer
I am using the MPI 12g Hi-Current No-Spark Arming Switch with Deans connectors. Works very well me. I bought from Radical RC
Old 05-26-2013, 03:06 PM
  #1482
vatechguy3
Can you post a pic of how you wired it in please?
Tony
Old 05-26-2013, 05:08 PM
  #1483
rightflyer
It is actually pre-wired so you just pick a location to mount it that works well for your batteries and esc.
Old 05-26-2013, 05:13 PM
  #1484
vatechguy3
Yeah I saw that, but I changed the ESC from a single male connector to add the series connectors.
Will post a pic of what I did soon.
Tony
Old 05-26-2013, 05:17 PM
  #1485
rightflyer
Ok. I just used a series adapter on the ESC but your way may be better long term.
Old 06-03-2013, 01:49 PM
  #1486
Jimmyzrx
Jimmyzrx's Avatar
I am just starting to build my Vanquish and going to install Hacker A60-7S not sure how to install this motor, I have seen the couple pics of drilling a hole thru the motor box.is there any more info on this install? Thanks Jimmy
Old 06-08-2013, 02:44 PM
  #1487
nosram
As a follow up to my post last month about the included hinges, I have been meaning to mention that when I went to instal the hinges a couple of them were tight. On inspection I found that the hinge rivet had been crimped off center. I then discovered that the rivet was aluminum. I also found that there was play between the pivet and plastic molding. I have replaced them with Robart, these have no slop and the rivet is made of steel. I assume that the steel will offer a better bearing surface.
Nick Marson
Old 06-09-2013, 09:19 PM
  #1488
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
ORIGINAL: vatechguy3
Talking to some guys at my field, do I need a spark arrestor to avoid sparks when plugging in theo batteries??
Tony
You do not need a spark arrestor. Most people don't use them, it is a preference option.
Old 06-10-2013, 08:31 PM
  #1489
kochj
can't you make a spark arrestor, buy placing a capacitor inline with the (+) line??
I didn't think it was anymore complicated than that?
The spark is actually an ARK? or do I know didly?
Old 06-11-2013, 09:43 AM
  #1490
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
You can make one. It is a resistor, not a capacitor. The idea is that you are making the connection from the battery to the ESC 'slowly' - you want the capacitors on the ESC to fill up slowly rather than instantaneously to avoid the ark (and yes, it is an ark). The resistor prevents the current from flowing to the ESC too quickly.
The commercially available spark arrestors are just an extra small set of +ive and -ive leads with a resistor and a momentary action switch. Here is a link that shows how to make one:
http://rc.runryder.com/helicopter/t547501p1/
Castle Creations has a comment about the 'spark being your friend' - please note that they tell you this so you are not afraid of the spark. a loud snap is somewhat of an indicator that the capacitors in the ESC are working properly, but it is not critical nor is it enough to tell whether or not your ESC is working properly.
Old 06-12-2013, 02:55 PM
  #1491
hovermaster
hovermaster's Avatar
Well, just came back from the D8 BARKS Pattern contest. The Vanquish flew excellent and with the Lords help I was able to win all 6 rounds in Masters.
Chris
Old 06-12-2013, 03:04 PM
  #1492
vatechguy3
Nice job Chris!!
Care to share your balance and control throws??
Tony
Old 06-12-2013, 03:17 PM
  #1493
rightflyer
Congrats, Chris! great looking plane.
Old 06-12-2013, 04:15 PM
  #1494
danamania
Congrats Chris!
Old 06-19-2013, 01:37 PM
  #1495
STEVE HOSNER
I have noticed quite a bit of interest in installing a Hacker A60-7s into the Vanquish.
I have put together a step by step guide showing how I have done this to my two Vanquish.
Here is hoping that this will be of some interest and help to those wanting to use the Hacker
motor.
I want to be clear that there are motors out there that will bolt right into the Vanquish without
the need for any modification. I have been impressed with the way these motors power the Vanquish.
I also am impressed with how the A60-7S powers the Vanquish. I am posting this just to help open
up the option of using another more affordable motor.
This being my first time at starting a new post I hope I did it correctly.
Thanks all,
Steve Hosner
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old 06-24-2013, 02:29 PM
  #1496
nosram
I have a question or two:
I have just got to the rudder horn installation. Are there any tips for this, please? Is 30 minute epoxy the best way to go, over say CA?
When opening up the slots is it better to remove material away from the hinge, towards the rear of the plane?
The instructions show the support plates with the opening towards the hinge. Would it be stronger to have the opening towards the ear of the plane?
Any advise will be very valued, thank you in advance,
Nick Marson
Old 06-25-2013, 06:24 AM
  #1497
Delicious J
Delicious J's Avatar
My New Vanquish is for sale unfortunately. Was just built and only has 8 flights. I crashed my pride and joy and need the funds to replace it.
The ad is here; http://www.rcuniverse.com/market/item.cfm?itemId=924349
and a ton more pics here; http://www.rcgroups.com/forums/showthread.php?t=1919381
Every single component was bought brand new and I have extras, and new packs included
Will meet in Texas for Pick-up
Old 06-25-2013, 05:16 PM
  #1498
nosram
Matt,
I am interested in your cells, the wing bag, APC props. I have evrything else I think.
Are the cell Zippy compacts?
Let me know,
Nick Marson
Old 06-28-2013, 05:24 PM
  #1499
aerobatix1
Hi Everyone,
I am looking to buy a Vanquish prefer ready to fly but open to any options. I am on the west coast near Sacramento. I sent a message to the 2 models listed in the classifieds but though it was worth posting here to see if someone may consider selling their setup.
Hope to hear from someone!
Thanks!
Rob Sarlan
Old 06-29-2013, 01:37 PM
  #1500
Delicious J
Sorry Nick, I wish I would have seen this sooner.
I have sold the batteries, but I still have the Hi-Max motor($210, shipped), jr servos, TP rx packs, switches, as well as a great Airframe bundle.
8 flights on airplane and all electronics. Receipts included with motor and servos for warranty.
Help me spread the word guys.....
Airframe, all servo extensions, 2 props, spinner, wing bags, extra canopy, extra rudder, extra horns, ..... $400 in Houston
Here is the ad
http://www.rcgroups.com/forums/showt...0#post25409374
