Puffy LiPo packs
My Feedback: (50)
Puffy LiPo packs
I've got a couple of Zippy and FliteMax 5000 10S packs that are getting soft and puffed up. Both packs charge OK and fly the 2M planes OK. At what point should I stop using them? When do the become unsafe to charge? Ive been using these packs regularly for about 2 years now. I don't keep records on them so I don't know how many cycles they have been through. Any battery experts out there that can help me know when to stop using and dispose of them?
Dave Burton
Dave Burton
RE: Puffy LiPo packs
Dave,
Without removing the heatshrink, it can often be hard to tell if the cells are really puffed, or it is trapped air. I would say it it more important to track the cell balance...almost all lipo packs will get "squishy" with age to some extent, and many will also increase slightly in volume.
If the balance on the packs is good at the end of charging and the end of flying, I'd keep running them. If you can measure IR, also keep an eye out for IR readings of a single cell that is substantially higher than the others - if you see that, the pack is not going to last much longer.
REgards,
REgards,
My Feedback: (50)
ORIGINAL: DaveL322
Dave,
Without removing the heatshrink, it can often be hard to tell if the cells are really puffed, or it is trapped air. I would say it it more important to track the cell balance...almost all lipo packs will get ''squishy'' with age to some extent, and many will also increase slightly in volume.
REgards,
Dave,
REgards,
I'll start checking the IR and balance and see how they look. Inless I see something out of line I'll just keep using them.
Dave. I
ORIGINAL: CLRD2LAND
Dave L.,
What is considered ''significantly higher''? Are we talking a cell that's .5 higher or 5 higher or are we talking a percentage?
Scott
Dave L.,
Scott
Regards,
