Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Dualsky Xmotor 6355DA-12T
Old 05-19-2012, 05:15 PM
NeilRivera
Default Dualsky Xmotor 6355DA-12T
Is anyone using this motor ? I have flown it 4 times in my Wind S Pro and would like to know what prop sizes others are using. I tried the APC 20-13 and it works great except that it over amps the motor so I used it without going full throttle. Any prop suggestions ?
Old 05-20-2012, 04:50 AM
RC_Pattern_Flyer
RC_Pattern_Flyer's Avatar
Default RE: Dualsky Xmotor 6355DA-12T
Possibly the 1912. Amps wil drop....victor diaz was running it in a vanquish.
chuck
Old 05-20-2012, 04:56 AM
RC_Pattern_Flyer
Also try the axi 2013..or other carbon props at that size.
Old 05-21-2012, 12:33 AM
Rombaut
I am using for monoplane 21x13 and for biplane Mejzlik-20x13.
Regards
Old 05-21-2012, 07:39 AM
NeilRivera
Ok after a little digging I finally figured it out, with the Apc 20-13 my motor was going over by 27 amps ! Talked to Victor Diaz and he suggested running the motor on low timing. I did and... voialá ! It now pulls exactly 75 amps at full throttle. I also had to program my Castle controller to "fixed" end points....
Old 05-21-2012, 08:55 AM
RC_Pattern_Flyer
Glad to hear that!
