Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
 hyperion 720i with Parallel charging board >
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 06-15-2012 | 06:21 AM
Default hyperion 720i with Parallel charging board
Guys,
My buddy recently bought FMA powerlab 6 with parallel board i was amazed that it can charge 4 5S 4900Mah batteries @ 7.5 amps at the same time, can I try this with my Hyperion 720i charger rated 500w x2. Anyone tried this setup? There's a parallel charging board for 6s in Hobbyking selling at $10. It would be awesome if you can charge 4 or 6 5S batts at the same. Any suggestions?
Old 06-17-2012 | 01:54 AM
rm's Avatar
rm
My Feedback: (27)
Default RE: hyperion 720i with Parallel charging board
You can parallel charge with any charger with the right connectors. You just need to have a power supply and power source large enough to handle your needs.
