Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Propeller size
Old 11-18-2012 | 08:38 PM
Default Propeller size
Hi
<div>Optimal size propeller "Turnigy G46 Brushless Outrunner 420kv" is</div><div>Is it 14 &times; 10?</div><div>To be mounted (3kg weight) to 60 class Zlin 50L.</div><div>The battery is 5S 4500mAh35 ~ 70C Lipo Pack.
</div>
Old 11-20-2012 | 12:18 AM
My Feedback: (182)
Default RE: Propeller size
Try the 15x8 for more thrust. Hobbyking site shows both 14x10 & 15x8.
If I have enough ground clearance, I woukd go with 15x8.
http://www.hobbyking.com/hobbyking/s..._46_Glow_.html
