Sebart 2M Wind SPro
Hey guys, do you know where you can buy spare parts for this Sebart 2M Wind SPro. A fellow flier, just bought one and the stab is twisted. Whenever the plane is inverted and he pushes, the plane always rolls right. the throws are equal on the elevator halves up and down, but there is a serious twist by 1 degree in the stab; hence the need for a new stab and elevator half.
thanks in advance
thanks in advance
Hi,
Check with F3A Unlimited, they sell Sebart planes and have some spares in their online shop, they have Wind S Pro stab set blue listed but not in stock but might be able to get what You need from US distributor ThunderPower
http://www.f3aunlimited.com/webstore...20a&page=2
Hacker in Germany has the "yellow" tail set in stock for Wind S Pro
http://www.hacker-motor-shop.com/e-v...929&p=2929
/Bo
/Bo
My Feedback: (25)
Robert,
Is the airplane in question the full composite, or does it have the built-up flying surfaces? If built-up, you could probably carfefully heat and apply tension to the stab in the opposite direction of the twist to remove it.
It may be worth a shot.
