what tool do you use to measue you elevator throws
I am looking for a better and more accurate way to measure the throws (in degrees) of the elevators, rudder, etc.
I have seen a device that clamps on you elevator (looks like a clothes pin) that measure both neg and positive throws.
Walfam
Walfam
My Feedback: (41)
http://www.centralhobbies.com/Tools/tool1.html#THROW
It's what I use for all my stuff. There is a possibility of using the digital readout meter from the incidence meter setup from Horizon, but I find it's too heaving for a lot of elevator setups to handle so I just use a pair of the little wooden analog devices....
FL
This is the cats meow for measuring throws: http://www.buddengineering.com/Merch...ategory_Code=P
The laser meter helps a lot on anhedral stabs as well, when regular pointers will move in/out and the elevators go up/down.
Jim W.
Jim W.
HI Jim,
I will have to consider this later in the year, but I do know Jerry Budd and have flown with him a few times. He supplies very quality items.
thank you for your assistance.
Walfam
Walfam
My Feedback: (8)
There is a slightly different version out there, this one goes for $3.99 but does not clip on:
http://www.3dhobbyshop.com/AJ-Throw-...s_p_15454.html
Great for a rough check (1/2 deg in 20 is only 2.5%) but that laser and ruler looks good,
Hi,
I use Hangar 9 Angle Pro 4-in-1 Digital Control Throw & Incidence Meter:
http://www.hangar-9.com/Products/Def...?ProdID=HAN193
http://www.hangar-9.com/Products/Def...?ProdID=HAN192
http://www.hangar-9.com/ProdInfo/Fil...Pro_Manual.pdf
/Bo
/Bo
