Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Lubing Neu gearbox
Old 02-02-2016 | 03:12 PM
OhD
Default Lubing Neu gearbox
I just cleaned and relubed an old Neu/gearbox that has been on the shelf for a long time. It feels extremely draggy when I rotate it by hand from the spinner. Is that normal or is there such a thing as too much grease? It's been so long since I tried to turn one over that I don't recall how it is supposed to feel. Any advice?
Jim O
Old 02-03-2016 | 09:38 AM
grotto2's Avatar
Something sounds wrong, Jim. I can feel the extra viscosity after a lube (it doesn't spin freely), but not like you're describing.
-Ron
Old 02-03-2016 | 03:10 PM
nonstoprc's Avatar
My Feedback: (90)
If you can quite freely rotate the shaft before attaching the gear box to the motor, then the problem could be somewhere else.
Old 02-09-2016 | 10:27 AM
grotto2's Avatar
Inquiring minds want to know.
Was this a real problem or just an OCD episode?
Old 03-01-2016 | 11:00 AM
OhD
A lot of OCD I'm sure. My wife says I only have it when it comes to RC airplanes. I don't think she means that as a compliment.
I finally got around to firing up the motor yesterday. I didn't like the sound of it at idle but it seemed to be fine overall during a run-up in the garage. I'm so used to the sounds of the contra, I don't remember how the Neu/gearbox should sound. There was no indication it was over lubed, so I'll go ahead and fly it and see how it performs.
Jim O
