Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
Reload this Page >
Oxai Galactika unboxing, assembly, setup, maiden etc.
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 11-01-2017, 12:21 AM
  #151
riot3d
Originally Posted by papaone
Hello Bem
Another modification
Claude
It looks like air brake on T wing for downline, two more moving surfaces also on T wing may be for snaps & rolling maneuvers? Counter-balance on rudder for more effective knife edge but yet can use a lesser torque & lighter servo?
I believe his whole idea is to have a mono plane similar to the performance of a bipe but don't want the hassle of an actual extra wing on top.
Adrian
Old 11-01-2017, 06:10 AM
  #152
papaone
papaone's Avatar
Hello
3 generations Jacques, Christophe and his son.
Claude
Old 11-01-2017, 07:19 AM
  #153
bem
Claude,
That is a very nice photo. It will be interesting to see if Christophe will be able to possess for two more years the King of the Belgians Cup individial throphy his son has in his hands in the photo.
/Bo
Old 11-02-2017, 11:50 PM
  #154
bem
Hi,
Some more photos of the Galactika + top wing and it's trailing edge control surfaces:
https://www.rcgroups.com/forums/show...5&postcount=31
/Bo
Old 11-16-2017, 03:13 AM
  #155
propnuter
Some more photos of CPLRs plane
Only the central airbrake was used. He experimented with the outer section but the breaking was too much. The outer sections are taped off.
Apparently the brake adds a pull to the belly reducing downline mix requirement.
ID:	2245213   Click image for larger version
ID:	2245214   Click image for larger version
Old 11-16-2017, 03:16 AM
  #156
propnuter
The belly canards improve knife edge and reduces the rud aileron mix required for extreme KE manueuvers.
I just gave Mr. Hebert a nose bleed ; )
You can see the internal mounting system used in my last post
ID:	2245217   Click image for larger version
Old 11-16-2017, 03:22 AM
  #157
propnuter
The wing is the same as the Galacktika wing with rounded wing tips in place of the pointed ones.
Old 11-16-2017, 06:01 AM
  #158
bem
Hi,
On my Galactika there it is a slight pull to canopy on downlines so such a break on top wing, if it correct that problem, would be a welcome enhancement on a Galactika.
/Bo
Old 11-16-2017, 06:03 AM
  #159
bem
Hi,
Are the belly fins removable or is it integrated (glued) in fuselage?
/Bo
Old 11-16-2017, 06:06 AM
  #160
bem
Hi,
Do You know if the shorter wingtips wing is the standard wing for the new "Galactika +" or was it only because of the high winds at WC in Argentina the shorter wingttips wing was used?
/Bo
Old 11-17-2017, 04:06 AM
  #161
propnuter
The belly fins are permanent. But could easily be made removable.You can see the attachment point on the belly of the internal photo i provided.The rounded wing tips will be standard on the G+. I think that the tips and rudder counter balance are just aesthetic changes.
Shane
Old 11-18-2017, 11:04 AM
  #162
Alfonso Garcia
Default T brake from Juan Rombaut
T brake is idea from Spanish F3A pilot Juan Rombaut. He is using it in his Cosmic full season. At F3A Bordeaux World Cup CPLR look at it and ask Juan to copy the idea. Since then they are sharing his experiences with T brake. It is used as airbrake when power is at idle and is really powerful, it is nice see how slow plane come down when T brake deployed, but Juan use full Spanish and bigger choro than CPLR. It need some elevador mixing and a powerful servo and strong transmission. My club F3A mate have the second Cosmic with T brake, set by Juan, and I have direct experience on it.
​​​​​​​Alfonso Garcia
Old 04-30-2018, 03:11 PM
  #163
bem
Hi,
Little update in this thread. Canged to Pull-Pull system for rudder in my Galactika. Made an own thread for that here:
http://www.rcuniverse.com/forum/elec...endations.html
/Bo
Old 05-01-2018, 10:30 AM
  #164
bem
Hi,
After 6 hours work with the soldering iron, shrink tube, tape, cardboard... 5 new LiPo packs ready for use in my Galactika.
It is Hacker TopFuel Eco-X 4600 mAh 20C F3A LiPo. Weight of 10 cell pack is from 989 gram to 993 gram.
I have changed from rudder servo in tail to rudder servo in front of fuselage with Pull-Pull for rudder to allow these lighter LiPo packs.
I need to be little gentle on throttle now so I do not ruin them by empty them below 20% capacity. I'm used to 5000 mAh LiPo.
Got my Galactika weight down to 4880 gram with these new LiPo packs.
One nice feature with larger Eco-X LiPo is that they have a voltage indicator and one can press a push button on that to have a small row of LEDs light up telling charge state. Good to check just before a pack is mounted in the plane before a flight, to avoid taking to the sky with a disharged LiPo.
I ordered the LiPo packs directly from Hacker in Germany and had them within a week.
The strange thing is after I had ordered them these special 4600 mAh F3A LiPo was not to be found anymore on Hacker homepage, and it is still not avaliable to buy today in their shop. I will e-mail them and ask, it would be good to be able to buy same LiPo packs in future if I need.
/Bo
Old 05-01-2018, 12:30 PM
  #165
big_G
Those terminals are trouble waiting to bite you. I would find some type with a sheath, like EC5's.
Old 05-01-2018, 01:07 PM
  #166
Eggert
Hello Bo. Greetings from DK
I also purchased the Special F3A packs from Hacker just in time to learn that they have gone away from the market.....
Wonder what that means ....In mild weather conditions i have 58 % left capacity in them after p19 and them are not hot
br Eggert
  #167
bem
Hi big_g,
I understand Your concern, but it might look more dangerous then it is.
The photo with the 5 LiPo packs in my previous post was taken directly after I had made the packs, so all bullet connectors was open and exposed.
Actually, when I store the packs they look like this, see photo below. When I use them in the plane I only take away the fuel tube on the red plus terminal.
Only when I charge the packs, for obvious reason, I have all 4 bullets connected to the charger (I use dual port charger, so one channel connected to one 5 cell pack and the second channel to the second 5 cell pack).
I have been using this for years. There is really not much other way You can do this if bullet connectors are in use.
I have used EC5 connectors many years ago in my 2M F3A planes. But I prefer bullet connectors since many years.
/Bo
Old 05-01-2018, 01:30 PM
  #168
bem
br Eggert
Hi Eggert.
I have e-mailed Hacker now and asked if the item no. 44600531 TopFuel LiPo 20C-ECO-X 4600mAh 5S Competition F3A 2017 is permanently or just temporarily removed from their webshop. I will come back here when they have answered.
I know some other guys here in Sweden that use these Hacker 4600 mAh LiPo and they seems to work fine.
regards,
Bo
Old 05-03-2018, 12:39 AM
  #169
bem
Hi,
I flew 5 flights yesterday evening after work with my Galactika (photo below after finnished for the evening), with the new Hacker Eco-X 4600 mAh Lipo (and the new Pull-Pull system for rudder).
All was fine, the plane flew as before (before the "enhancements") but the plane has sligtly better vertical performance now since it is lighter.
I think I have little to much play in the rudder servo gear now so I will change rudder servo (Futaba BLS171 SV) to a new same (spare I have).
I had flown about 12 flights with my reserve plane, MythoS Pro, last week just to warm up and it is rather much difference in flight characteristics between MythoS Pro and Galactika.
I have same motor in both, Hacker Q80-14XS and Master Mezon ESC but I use different propellers, on MythoS Pro I have Falcon Electric Carbon V2 21.5 x 14.5 and on Galactika Falcon Electric carbon V2 21x14.
MythoS Pro has an overall slower cruise speed and is slower in vertical downlines. Both ESCs are configured the same regarding the break. Galactika is faster in general but little more precise in most manouvres. The biggest disadvantage in my opinion with Galactika is that it is faster in general (and do not really fly good if flown slow in my opinion) and is also faster in vertical downlines. This is a rather big disadvantage since there is less time to perform maneouvres and it is easy to be behind in the flying so to speak. Galactika is rather sensitive to center of gravity also, compared to MythoS Pro.
What I really want on Galactika is slower downlines, maybe some change in brake settings could help, I do not know, but since I have same brake settiings in both my Master Mezon ESC it should not be that big difference maybe. Perhaps the different props gives the result I see? If anyone clever have any suggestion on this It is welcome and I will try it. Probably the new "Galactika+" (Plus) with its top wing with break is the key to get real slow vertical downlines with Galactika? If anyone that has a Galactika+ and read this please post Your impression on vertical downlines.
regards,
Bo
Galactika at the field May 2, 2018.
Old 05-04-2018, 02:06 AM
  #170
bem
Originally Posted by bem
Hi Eggert.
regards,
Bo
Hacker have the special 4600 mAh Competition F3A LiPo in their shop again now (not in stock but possible to order at least):
https://www.hacker-motor-shop.com/Brushless-Motors/F3A/F3A-drive-accessories/TopFuel-LiPo-20C-ECO-X-4600mAh-5S-Competition-F3A-2017.htm?shop=hacker_e&SessionId=&a=article&ProdNr=44600531&p=10414
I also got a newsletter from Hacker today and they have a new special 5100 mAh 20C Competition F3A 2018 LiPo now also.
Reasonable light, 2 x 548 gram = 1096 gram for 10 cells. That is about 130 gram lighter then 2 x 5 cell of their regular Eco-X 5000 mAh 20C.
https://www.hacker-motor-shop.com/Brushless-Motors/F3A/F3A-drive-accessories/TopFuel-LiPo-20C-ECO-X-5100mAh-5S-Competition-F3A-2018.htm?shop=hacker_e&SessionId=&a=article&ProdNr=45100531&p=10414
/Bo
Old 05-07-2018, 05:13 AM
  #171
kobi
Hi bem
Maybe try it to slow vertical downlines
Like CPLR
regards,
Kobi
Old 05-07-2018, 06:17 AM
  #172
bem
Kobi,
I wonder if Hui Yang Professional F3A has this top wing (canalizer) with break as standard feature today for Galactika+?
If it would help both to reduce dowline speed and help reduce pull to canopy in downlines it would for sure be an interesting alternative to consider.
/Bo
Old 05-10-2018, 03:07 PM
  #173
bem
Hi,
I was out flying today, it was very windy. I had luck: when I unloaded my Galactika from the car at the field I placed it behind the car briefely and then reached for the bag where I have two screwdrivers with strings, to attach to the wheels/landing gear into the ground. While I reached for the bag there was a strong wind gust throwing Galactika up in the air (no wing was mounted but the canalizer was mounted and it's protection cover, as well as stab+fin cover) and it landed upside down. It landed upside down vertically and did not land on its side. And that was my luck, not a scratch on top wing or anyting else on the plane. Previous season I was not so lucky when same thing happened but then the top wing broke. It was my lucky day today obviously. The flying was fine despite the hard wind, about 10 flights before I thought it was enough for the day.
There was a sailplayne flyer out flying at the field also, he was flying F3B (with a plane "Dopamin"), and a helicopter pilot, flying F3C (with SAB Globlin 700).
/Bo
Old 05-11-2018, 04:32 AM
  #174
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
Bo,
Interesting story.
Back here in central Texas, strong south wing is also very common (25-30 MPH). What that I found a useful procedure to prevent the plane from being blown away is as follows.
1. Install the power battery pack while the fuze is still in the car;
2. move the fuze out of the car to the ground;
3. attach additional weights to the landing gear/tail-wheel assembly if necessary;
4. install the wings;
For windy days, I use some exercise sand bags about 1 lb each to attach to the landing gears. There are Velco straps on the sand bag so the attachment is straight forward.
Even in a calm day, I always leave the power battery pack in the plane.
Old 05-11-2018, 09:16 AM
  #175
bem
nonstoprc,
Another way to prevent a plane from taking off the ground by itself in strong winds can be to use a neckstrap around the spinner/prop and attached to a screwdriver into the ground, like this (an Ascent Biplane owned by a Norwegian F3A flyer). Plane should be set with nose pointing into the wind.
