Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Servo horn
Old 11-04-2018 | 05:14 AM
rgreen24's Avatar
Default Servo horn
I normally use the large Dubro Futaba servo horns on my pattern models. The question I have is what are most people using for servo horns? I have seen some carbon fiber arms as well, are people using these and if so where are you buying them?
Old 11-05-2018 | 12:46 AM
Robert,
I typically use the large round Futaba horns for ailerons, and the small regular sized single sided Dubro arms for elevator.
Old 11-05-2018 | 04:40 AM
rgreen24's Avatar
Thanks Chuck, been seeing more people do this and it seems to make sense. Was talking with a friend over the weekend about how to get more throw if you use the horn you mentioned and I think it's going to work perfectly
