Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
TP 1010C charger
Old 01-17-2007 | 05:07 PM
rgreen24's Avatar
Default TP 1010C charger
Do you guys know if this charger will allow you to charge two seperate 5S 2P PACKS AT THE SAME TIME?
TIA
Old 01-17-2007 | 05:58 PM
Default RE: TP 1010C charger
It will charge 2 5S at up to 5 amps in series. You can charge 2 5S at up to 10 amps in parallel. The balancer will not support the parallel config though. But you can always balance them separately first.
Old 01-17-2007 | 08:14 PM
Rob: Yes....you can build a wiring harness to place the two 5S packs in series and charge them with a TP1010C. A TP210 balancer can be used to keep the cells in both packs balanced. For a fully depleted F3A pack, it will take about an hour to charge it.
Mike
Old 01-17-2007 | 09:24 PM
rgreen24's Avatar
Thanks Mike.
