Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
 cyclone f3a test with eagle tree >
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 01-19-2007 | 05:01 PM
Default cyclone f3a test with eagle tree
hi to all i wan to show you my test on the ground with the cyclone engine
engine cyclone f3a
speed controller cyclone pilot pro 120
batteries thunder power extreme 5000mha 10s
prop apc 20x12
rpm 6500
data with eagle tree micro power
enjoy
marcelo
Old 01-22-2007 | 06:26 PM
uro
Default RE: cyclone f3a test with eagle tree
Marcelo how weight you add with eagle tree telemetry.
bye
daniel
saludos
Old 01-22-2007 | 09:55 PM
hola danile muy bonito lugar , espero algun dia poder ir a uruguay a compartir algunos vuelos con ustedes, el aparto de eagle tree pesa tan solo 17 gramos, por lo que nose nota en el modelo
y te comento que es muy bueno por que sabes exactamente que pasa en tu modelo mintras vuelas
saludos
desde san juan
argentina
marcelo zini
Old 01-23-2007 | 12:51 AM
KeithB's Avatar
Those are some pretty high amperage draws!
Keith B
Old 01-23-2007 | 02:14 AM
And even then, the voltage is 35V+. That's pretty good.
Magne
Old 01-23-2007 | 09:33 AM
hi this graph is a 3d flight about 8minutes , with hover, rolling harrier and very hot day about 39 degres celcius
cyclone f3a
pilot pro 120 esc
apc 20x12w
tp extreme 5000mha 10s
genesis 3d plane
