Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
 QUESTION ABOUT TRIMMING (MIXING) >
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 01-27-2009 | 05:52 AM
From: Bishop\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'s Stortford,
Default QUESTION ABOUT TRIMMING (MIXING)
Perhaps some one could advise. One of my models requires a little down mix with low throttle. I presume if this is the case then this mix, unlike most other mixes such as rudder - aileron, is left on only temporarily and taken off for landing.
Old 01-27-2009 | 07:25 AM
exeter_acres's Avatar
Default RE: QUESTION ABOUT TRIMMING (MIXING)
I turn mine off.....it is part of my landing condition...
lower idle on the engine and turns off the down line mix.....
Old 01-27-2009 | 09:43 AM
tIANci's Avatar
Yeah ... what Nigel asked is something I liked to know too. I put my mix on a switch and I only switch on the mix when I am doing downlines and certain uplines. On level flight I feel the mix pulling the plane down on low or high throttle. Do most people switch it off for level flight or is it because I am so used to holding UP elevator that with the mix on I am just not used to the difference?
